请帮帮我,optistruct报错
浏览:1862 回答:1
 *** See next message about line 1705749 from file: zhengche.fem
 "CTRIAX6   520957       0  353145          353144          118378"
 This line was interpreted as:
1705749:CTRIAX6, 520957, 0, 353145, , 353144, , 118378
 *** ERROR # 1000 *** in the input data:
Incorrect data in field # 3.
 Expected INT > 0, found  INTEGER (0).
具体怎么改呢,不知轴对称单元哪里没附上属性
哄哄_7502
想问下hyperworks里怎么设置四边形的轴对称单元呀?
2022年3月29日
