The maximum contact stiffness is too big?
浏览:5711 回答:4
仿真过程中出现The maximum contact stiffness is too big. This may affect the accuracy of the results. You may need to scale the force unit in the model. 我的结构是一个铜薄片上面是一层柔性层
是error还是warning,金属和柔性体做接触,接触参数要好好设置,否则负体积
