Ansys 如何用APDL将自定义梁截面的截面特性信息写入TXT文件?
浏览:1756 回答:3
Ansys 如何用APDL将自定义梁截面的截面特性信息写入TXT文件? 自定义了梁截面,希望将梁截面特性(AREA, Iyy, Izz,等信息)写入文件,
蓝牙
这是3个自定义梁截面的命令流,你参考下
2019年12月30日
蓝牙
finish
/clear
!(1)设置工程属性
/filnam,static
/UNITS,MPA    !MPA system (mm, Mg, s, °C)
/prep7
/view,,1,1,1  !设置图方式形显示MPA system (mm, Mg, s, °C)
et,1,mesh200,6
keyopt,1,1,7
k,50001,-20,-30,0
k,50002,-20,30,0
k,50003,8,32,0
k,50004,40,30,0
k,50005,40,30-2.5,0
k,50006,40-17.5,30-2.5,0
k,50007,40-17.5-2.5,30-2.5-2.5,0
k,50008,40-17.5-2.5,-30,0
*do,i,1,7
l,i+50000,i+50001
*enddo
l,i+50001,50001
aL,1,2,3,4,5,6,7,8
K,50009,-18,-27.5,,
K,50010,-18,27.5,,
K,50011,18,27.5,,
K,50012,18,-27.5,,
a,50009,50010,50011,50012
ASBA,       1,       2
LWPL,-1,12
ASBW,all
LWPL,-1,12,1
ASBW,all
KWPAVE,   50003
ASBW,all
KWPAVE,   50006
ASBW,all
LWPL,-1,11,1
ASBW,all
KWPAVE,   50007
ASBW,all
KWPAVE,   50011
ASBW,all
CSYS,1
AGEN, ,all, , , ,90, , , ,1
CSYS,0
LESIZE,all,1, , , , , , ,1
MSHAPE,0,2D
MSHKEY,0
amesh,all
secwrite,LT_I,sect,,1
finish
/clear
!(1)设置工程属性
/filnam,static
/prep7
et,2,mesh200,6
keyopt,2,1,7
et,1,mesh200,6
keyopt,1,1,7
k,50001,0,-30,0
k,50002,0,32,0
k,50003,8,32,0
k,50004,40,30,0
k,50005,40,30-2.5,0
*do,i,1,7
l,i+50000,i+50001
*enddo
l,i+50001,50001
aL,1,2,3,4,5,6,7,8
K,50009,0,-27.5,,
K,50010,0,27.5,,
K,50011,18,27.5,,
K,50012,18,-27.5,,
ASBA,       1,       2
LWPL,-1,12,1
KWPAVE,   50012
ASBW,all
KWPAVE,   50006
ASBW,all
LWPL,-1,11,1
ASBW,all
KWPAVE,   50007
ASBW,all
KWPAVE,   50006
ASBW,all
ARSYM,X,all, , , ,0,0
AGLUE,all
CSYS,1
CSYS,0
MSHAPE,0,2D
MSHKEY,0
amesh,all
secwrite,LT_II,sect,,1
finish
/clear
!(1)设置工程属性
/filnam,static
/prep7
et,1,mesh200,6
keyopt,1,1,7
k,50001,-20,-30,0
k,50002,-20,30,0
k,50003,8,32,0
k,50004,40,30,0
k,50005,40,30-2.5,0
*do,i,1,7
l,i+50000,i+50001
*enddo
l,i+50001,50001
aL,1,2,3,4,5,6,7,8
K,50009,-18,-27.5,,
K,50010,-18,27.5,,
K,50011,18,27.5,,
K,50012,18,-27.5,,
ASBA,       1,       2
LWPL,-1,12
ASBW,all
LWPL,-1,12,1
ASBW,all
KWPAVE,   50003
ASBW,all
KWPAVE,   50006
ASBW,all
LWPL,-1,11,1
ASBW,all
KWPAVE,   50007
ASBW,all
KWPAVE,   50011
ASBW,all
ARSYM,X,all, , , ,0,1
CSYS,1
CSYS,0
MSHAPE,0,2D
MSHKEY,0
amesh,all
secwrite,LT_III,sect,,1
2019年12月30日
