ABAQUS6.14.4调用子程序之后出现1073741819错误代码,如何解决?
浏览:2273 回答:1
监控中的提示信息:The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
静默的无线电
一个是改mkl文件名,还有就是检查下子程序有没有写错,有的时候数组维度不对也会导致这个问题
2020年1月14日
