用ANSYSlsdyna板块建完模型生成k文件时弹出错误,请指教到底哪里的问题?
浏览:1464 回答:4
No Explicit Dymamic material model was defined for material 2 due to either missing material data or defining the material model before setting the preferences for Explicit Dynamic Analysis.Please check definition of materials for Explicit Dynamic Analysis and redefine the material model if necessary.
数智氢芯
生成的k文件去prepost检查和修改
2020年1月16日
已采纳 评论 3 点赞
