为什么提交作业的时候会出现这种错误? 20
浏览:2633 回答:4
The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively.
There is only one excessively distorted element
The ratio of deformation speed to wave speed exceeds 1.0000 in at least one element. This usually indicates an error with the model definition. Additional diagnostic information may be found in the message file.
Abaqus/Explicit Analysis exited with an error - Please see the status file for possible error messages if the file exists.
在计算过程中单元发生了扭曲,可以通过后处理中来检查是哪些单元发生了扭曲
