ABAQUS msg文件里全是这些是什么原因?
浏览:3521 回答:2
 max. penetration error 35.2349e-12  at node con-1.3486 of contact pair
   (assembly_s_surf-176,assembly_m_surf-176)
   max. contact force error -26.2825      at node con-1.9472 of contact pair
   (assembly_s_surf-181,assembly_m_surf-181)
          the estimated contact force error is outside of convergence tolerances.
 average force                       5.40       time avg. force        3.04
 largest residual force              24.1       at node       5688   dof  1
   instance: con-1
 largest increment of disp.        -1.479e-06   at node         23   dof  1
   instance: stud-1-lin-1-3
 largest correction to disp.        9.011e-07   at node         23   dof  1
   instance: stud-1-lin-1-2
          force     equilibrium not achieved within tolerance.
凌烟阁
1)主从面建模的时候穿透,2)dof1 应该是释放了吧,可以建个临时约束,接触稳定后再放掉
2020年5月12日
评论 点赞 1
于锡贺
你好,我也遇到了,请问你解决了吗
2022年8月12日
