xflow相关问题? 20
浏览:1417
project.xfd not found. Please run the domain generator before running the engine.
Indicates the engine is running without the fluid domain generated (project.xfd). Run the executable generateDomain3d to generate the fluid domain.
请问一下Run the executable generateDomain3d to generate the fluid domain.的具体操作是什么
