LNG储罐模拟的问题?
浏览:1386 回答:1
出现以下错误:
Normal cannot be computed in 16 elements. The nodal coordinates may be incorrect or the element aspect ratio may exceed 1000 to 1. The elements have been identified in element set ErrElemNormal.
The geometry of 16 elements is too distorted. Check the nodal coordinates or node numbering on elements identified in element set ErrElemDistorted.
哪位大神知道这是什么错误嘛
郑钧 Adam
錯誤訊息看起來都是網格的問題,可以從後處理檢查這些位置的元素
2020年5月22日
