gambit安装后的运行问题
浏览:60371
各位大虾好!我刚安装上gambit 2.3.16,也把license.dat复制到了对应文件夹下,但是运行时却显示如下内容,无法正常启动。请各位大虾解释一下怎么回事,应该怎么解决呢?先谢谢啦!
Warning : The current transport does not permit the attempted TCPIP connection.
TRANS(SocketINETGetAddr): tnamebysocket() failed
TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
TRANS(Open): transport open failed for tcp/thinkpad-t61:0
Unable to open display
