求助
浏览:144349
本人新手,在用ansys算简单结构:一块板,板下布有纵梁和横梁,由纵梁支撑在支座上。采用SOLID45单元划分,约束施加在纵梁底部节点上,三向约束,总是求解不成,警告如下:
*** WARNING *** CP = 659.250 TIME= 23:32:22
Smallest negative equation solver pivot term encountered at UZ DOF of
node 63196. Check for an insufficiently constrained model.
如果将横梁去掉即可求解,请教各位高手是什么原因?
