请问大神,为什么FLUENT中,enhanced wall treatment 不能考虑壁面粗糙度? 10
浏览:1775 回答:1
考虑A类地貌的话,壁面粗糙都的两个参数应改怎么设置呢
jiujiu
Rough walls cannot be used together with the following model combinations:
• an -equation model with enhanced wall treatment or the Menter-Lechner near-wall
treatment
Note that the following are the relevant -equation models:
– all of the - models (that is, standard, RNG, and realizable)
– the Reynolds stress model with the Linear Pressure-Strain model selected
– the detached eddy simulation (DES) model with the Realizable k-epsilon option selected
• the Reynolds stress model with the Stress-Omega or Stress-BSL model selected
2021年3月1日
