ansa前处理,lsdyna求解报错怎么解决?
The LS-DYNA time step size should not exceed 1.003E-08 to avoid contact instabilities. If the step size is bigger then scale the penalty of the offending surface. too many prescribed nodal displacements for rigid body part ID 8 limit=1. Nodal list: *** Error 30006 (INI+6) initialization completed with 3 or more fatal errors please check messag file Memory required to begin solution : 9457818 Additional dynamically allocated memory: 4663760 Total: 14121578 *** Error 30006 (INI+6) initialization completed with 3 or more fatal errors please check messag file
全部回答 (2)
其中一个错误时内存设置问题 你设置100000000 应该就够用了
2020年6月10日
第一个时间步控制不能超过1e-8
第二个刚体part8规定的位移节点太多,一般只能一个
第三个内存不够,K文件添加MEMORY=800000000000
