abaqus仿真切削碳纤维复合材料出现了错误? 10
浏览:1288
abaqus仿真切削碳纤维复合材料(碳纤维和树脂是分别定义的属性),采用了动态,温度位移,显示的分析步类型,仿真出现错误(Degree of freedom 11 and least one of degrees of freedom 1 thru 6must be active In the model for*dynamic temp-disp. Check the procedure and element types used In This model)有知道这个错误是什么意思的吗?怎么改呢?
