顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
ABAQUS新手急需帮助
浏览: 4291 回答: 1
4508 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
Integration and section point output variables will not be output for deformable elements that are declared as rigid using the *rigid body option
Output request s is not available for element type conn3d2
Output request svavg is not available for element type conn3d2
Output request svavg is not available for element type c3d8r
The option *boundary,type=displacement has been used; check status file between steps for warnings on any jumps prescribed across the steps in displacement values of translational dof. For rotational dof make sure that there are no such jumps. All jumps in displacements across steps are ignored
警告提示,无法运行作业怎么办
全部回答 (1)
why_0948 2023年4月20日
应该是约束条件设置的不正确,再去检查一下约束
2023年4月20日
相似问题
查看全部
  • 大佬帮忙看看问题出在哪里了,感谢? 1个回答
    For two-dimensional models, if a non-unity thickness is specified for two-dimensional solid elements and these elements are involved in an interaction such as contact, the same thickness should be spe
  • 【ABAQUS--设置连接器】梁两端设置连接器不收敛? 4个回答
    麻烦大家指导下~~~~ ABAQUS模拟杆件系统中,一个杆两段均设置非线性轴向连接器,一开始就不收敛算不过去。尝试过一端连接器,一段MPC-tie连接可以收敛,希望大神指导下~~ 错误警告: One or more thickness of the box section is greater than 0.1 of the cross section dimension. The torsion
  • ABAQUS问题? 4个回答
    我用的是UMAT子程序,出现以下问题: The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error mess
推荐阅读
Fluent UDF视频教程
Fluent UDF视频教程
技术邻小李 技术邻小李
¥200
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
使用已标定的车辆动力学模型提升开发效率
使用已标定的车辆动力学模型提升开发效率
VI-grade中国 VI-grade中国
免费
hypermesh_dyna小车碰撞护栏(无声)
吴文泽 吴文泽
¥18
abaqus lamb波传播分析
abaqus lamb波传播分析
abaquser abaquser
¥25
