ABAQUS轴对称模型中出现错误提示,怎么解决?
浏览:1273 回答:1
Error in job Job-1: NODE OUTPUT ON EXTERIOR NODES HAS BEEN SPECIFIED. HOWEVER, THERE ARE NO ELEMENTS IN THE MODEL FOR WHICH THIS TYPE OF OUTPUT IS SUPPORTED. NODE OUTPUT ON EXTERIOR NODES IS SUPPORTED ONLY FOR 3-D CONTINUUM ELEMENTS AND SHELL AND MEMBRANE ELEMENTS, EXCEPT AXISYMMETRIC SHELLS AND MEMBRANES.
