abaqus调用子程序Dflux分析时,出现很多以下警告,算不过去了。有前辈可以帮忙解决一下吗? 66
There is zero HEAT FLUX everywhere in the model based on the default criterion. please check the value of the average HEAT FLUX during the current iteration to verify that the HEAT FLUX is small enough to be treated as zero. if not, please use the solution controls to reset the criterion for zero HEAT FLUX. HEAT FLUX equilibrium accepted using the alternate tolerance.
全部回答 (1)
热流为0.可能是没加上
2020年7月31日
评论 2 点赞
