为什么abaqus子程序umat去掉write语句就不能算了?
浏览:1449 回答:3
debug子程序umat的时候发现,此处加了write语句可以算,
CC------------------------------------------------------C
c       WRITE (7,*) 'DDSDDE=1'!!!!加
       DO 100 IN=1,NTENS
        DO 200 JN=1,NTENS
c       WRITE (7,*) 'DDSDDE='!!!!加
         DD_TEM=0.0D0
          DO IS=1,42
          DD_TEM=DD_TEM+A_TEM(IN,IS)*B_TEMNEW(IS,JN)
          ENDDO
         DDSDDE(IN,JN) = DDSDDE(IN,JN)-DD_TEM*DETERINV
200      CONTINUE
100      CONTINUE
c       WRITE (7,*) 'DDSDDE=',DDSDDE
      ENDIF
CC--------------------------------------------------------C
       RETURN
       END
去掉之后出现错误:
Abaqus Error: The executable standard.exe aborted with system error code 1073741819.Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. Abaqus/Analysis exited with errors
章鱼_9976
兄弟,找到问题了吗?
2023年10月16日
SnowWave02
查看.log有没有提示编译哪行出错
2020年8月5日
