提交作业后,cohensive节点重合错误? 50
浏览:1718 回答:2
在模型中插入0厚度的cohensive层后,提交作业,错误为A facet that is part of a general contact surface has coincident nodes. A facet with coincident nodes cannot be part of a general contact surface. See nodes 663 and 7763 on element 4801 of instance PLATE-1. Please check the nodal coordinates of nodes of this element. Also, please check if these nodes are slave nodes in a *TIE definition. Adjusting the slave node coordinates of improperly defined *TIE definitions may cause excessive distortions of the underlying elements resulting in collapsed facets. If the nodes are slave nodes in a *TIE definition, please check the *TIE definition for consistency, making sure that there are no common nodes between the slave and master surfaces.
请大神帮助,感激不尽
Wind12306
找到并去掉重合那些节点,错误自然解决
2020年8月13日
评论 点赞 1
须佐套大佛
老哥,你解决了吗,我也遇到类似的问题了,你咋处理的,可以教教我吗
2023年10月31日
