hypermesh 仿真报错 ,求大佬指示?
浏览:1566 回答:3
error#51
Element 597722 is of invalid type for PLOAD4 data.
*** ERROR #  51 ***
 *** ERROR #  51 ***
 Element 597723 is of invalid type for PLOAD4 data.
 *** ERROR #  51 ***
 Element 597724 is of invalid type for PLOAD4 data.
 *** ERROR #  51 ***
 Element 597725 is of invalid type for PLOAD4 data.
 *** ERROR #  51 ***
 Element 597726 is of invalid type for PLOAD4 data.
 *** ERROR #  51 ***
 Element 597727 is of invalid type for PLOAD4 data.
 *** ERROR #  51 ***
 Element 597728 is of invalid type for PLOAD4 data.
 *** ERROR #  51 ***
 Element 597729 is of invalid type for PLOAD4 data.
 *** ERROR #  51 ***
 Element 597730 is of invalid type for PLOAD4 data.
 *** ERROR #  51 ***
 Element 597731 is of invalid type for PLOAD4 data.
 *** More of ERROR messages # 51 were suppressed...
 Too many error messages. Aborting run.
 Current limit is 10000. Use "MSGLMT" control card to change this value.
 Following warning messages appeared too many times
 and were suppressed:
      51
 Total of 9989 repeat error message(s) were suppressed.
 To see more messages use "MSGLMT" control card in the data or config file.
bluer_6128
压强载荷和单元类型不匹配
2020年10月4日
Tim.Ding
你这单元有问题,检查一下单元质量
2020年10月3日
