abaqusUMAT和生死单元同时可以使用吗? 100
浏览:1787 回答:2
我将材料用了一个UMAT子程序,又设置了一个生死单元,计算时报错
10/11/2020 4:32:24 PM Run standard.exeUnexpected LoadLibraryA error 193
10/11/2020 4:32:31 PM Abaqus Error: The executable standard.exe aborted with system error code 1073741819.Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. Abaqus/Analysis exited with errors
UMAT单独在一个小例子上是可以计算的,单独设置生死单元(modelchange)用自带本构也是可以计算的,请问这是出了什么问题?
William_7427
前辈解决了吗,我也遇到同样的问题了
2024年11月20日
静默的无线电
这个问题先试下改下mkl文件名
2020年10月12日
