UMAT提交后出现以下问题怎么解决? 20
浏览:1676 回答:3
UMAT提交后出现以下问题怎么解决?的图1log.txt
UMAT提交后出现以下问题怎么解决?的图2dat.txt
UMAT提交后出现以下问题怎么解决?的图3inp.txt
UMAT提交后出现以下问题怎么解决?的图4msg.txt
abaqus提交工作后出现了下面的问题,请问是什么原因
作业输入文件 "Job-2.inp" 已提交分析.
Job Job-2: Analysis Input File Processor completed successfully.
ERROR in job messaging system: Error in connection to analysis
Error in job Job-2: The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist.  If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information.  Use the same command to run Abaqus that you used when the problem occurred.  Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job Job-2 aborted due to errors.
附件里有inp文件,dat文件,msg文件,log文件里面报错了,但是不知道是什么原因导致的错误,求大神帮忙看一下
静默的无线电
先试下改一下mkl文件名
2020年10月23日
评论 2 点赞
