abaqus和Python相结合进行结构优化
浏览:1556
Abaqus Warning: The following input options are not supported by parallel execution of element operations: buckle. Only the solver will be executed in parallel for this analysis.我用ABAQUS PYTHON二次开发攻略这本书中的一个优化案例去跑程序,发现abaqus报了上面的错误,有大佬知道怎么解决吗?
