ABAQUS动力显示出现error code3请问是什么原因?
土-结构地震分析模型15w网格,静力和隐式可以计算,但显示Explicit提交计算后0.006s就Errors了显示:The executable explicit_dp.exe aborted with system error code 3. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.请问是什么原因导致的这种情况,显示分析相对于隐式不是更好计算且效率更高吗?为什么我这个情况反了呢又慢又算不下去?
全部回答 (1)
我也遇到此问题,我是Windows 10 专业版系统、AMD R9-5950X处理器、Abaqus6.14-4 Explicit分析,一开始Job里设置的多线程 10个、进行Data Check的时候是成功的,提交运行一开始是正常运算并有结果输出,然后突然出现The executable explicit.exe aborted with system error code 3. 错误。不知为何,后来我降Job里设置改成默认的 线程数为 1个,其它没有任何改动,结果再提交分析就能一直正常运行了。
