hypermesh 分割平面出现的问题
浏览:1798 回答:1
在画hypermesh时,geometry. surface edit. trim with node,将两个点连线分割时出现nodes with gold. were removed. less than two nodes were selected to trim,以至于两个点连不上
Zl1232140
要不是node没选到2个,要么2个node不在同一个面上。
2020年11月11日
评论 点赞 1
