求解,做的是hyperworks 的模态法瞬态分析,一开始说我内存不够,现在就出这个问题,如何解决?
浏览:1453 回答:1
 *** INFORMATION # 2431
 Inertia relief is being switched on for RESVEC
 calculation in modal FRF/transient analysis
 for subcases with no SPC (free-free structure).
 Please use param,inrel,0 to turn off this effect.
 NOTE # 113
 RESVECs are not created for distributed static loads
 referenced in modal FRF/transient analyses.
 *** ERROR # 291 ***
 No output results requested for Frequency Response, Transient Analysis
 or Random Response.
 Note that displacements and stresses are disabled by default for such
 loadcases. Also note that the amount of results for such loadcases may
 be extremely large, and therefore output SETs are highly recommended.
OPTIMIZATION FILE AND PARAMETER INFORMATION :
  FEM model file               :
     E:/chekubuduichenmoxing1019+1029dandiandizhen+111+118+jichuzhendonggaibiankapian.fem
  Output files prefix          :
  Model read from files:
Tim.Ding
缺少约束
2020年11月10日
