用abaqus做一个三层混凝土框架结构的模态分析是一下错误怎么解决? 10
浏览:1540 回答:1
错误提示:Three factorizations in a row failed. Check the model. It is possible that the model contains the kinematic coupling definition set up in a way that a degree of freedom has neither mass nor stiffness.
结构图:
