求助ANSYS LS-DYNA求解问题!请大神指导一下!? 200
浏览:1639 回答:7
毕业论文在用ANSYS LS-DYNA做汽车与混凝土护栏碰撞。提示ANSYS LS-DYNA run is done with 412 WARNING. Please check the message file.我查看了下message文件里警告信息,网上查了下说是初始穿透问题,有一条解决办法是考虑壳单元厚度,我考虑了警告更多。很奇怪的一点是我的上部车辆模型轮胎最低点坐标一样,下面是平面,结果好像穿透的坐标存在差别还是什么,没能消除警告,想问下是不是这个原因导致计算到此结束不继续求解完成吗?这种情况跟求解完成的已出结果一样吗,能不能帮我看下message信息,最好能提示一下解决办法,真的感激不尽,我想毕业!!!!(以下展示部分警告内容)
 *** Warning 40570 (SOL+570)
     Initialization - node will not be moved
     penetrating node is too far below surface
     single surface interface #             = 1
     penetrating node #                     = 622784
     segment #                              = 290046
     penetration                            =  3.6539E-02
     remaining distance to shell midsurface =  0.0000E+00
     s,t                                    = -1.0000E+00  1.1087E-08
     penetrated segment nodes:
 616721 620610 620565 620565
     penetrating node #                     = 622785
     segment #                              = 290051
     s,t                                    = -1.5050E-10 -1.0000E+00
 616722 620565 620611 620611
     penetrating node #                     = 622787
     segment #                              = 289940
     s,t                                    =  1.1087E-08 -1.0000E+00
 616707 622775 662196 662196
     penetrating node #                     = 622789
     segment #                              = 289952
     s,t                                    = -1.0000E+00 -1.5050E-10
 616708 662197 622775 622775
     penetrating node #                     = 716225
     segment #                              = 272069
     penetration                            =  1.0000E-02
     s,t                                    =  1.7287E-01 -4.4720E-01
 194567 191018 189728 189728
     penetrating node #                     = 716226
     segment #                              = 275882
     s,t                                    =  7.4614E-02 -9.3025E-01
 194487 191051 191050 191050
     penetrating node #                     = 716227
     segment #                              = 275964
     s,t                                    = -7.7027E-01  7.4175E-01
 191083 191653 191654 191654
     penetrating node #                     = 716228
     segment #                              = 272657
     s,t                                    =  1.7826E-01 -5.0891E-01
 194322 191116 189826 189826
     penetrating node #                     = 716229
     segment #                              = 276126
     s,t                                    =  9.0305E-02 -9.4684E-01
 194242 191149 191148 191148
     penetrating node #                     = 716230
     segment #                              = 276207
     s,t                                    = -8.1074E-01 -7.6929E-01
 192193 191181 192192 192192
     penetrating node #                     = 716231
     segment #                              = 273245
     s,t                                    =  1.8022E-01 -4.8052E-01
 194077 191214 189924 189924
     penetrating node #                     = 716232
     segment #                              = 276370
     s,t                                    =  4.3534E-02 -8.9914E-01
 193997 191247 191246 191246
 Summary of initial penetration for interface #= 1
   number of warning messages                  = 412
   number of nodes that are moved              = 412
   min penetration distance                    =  6.2743E-04
   max penetration distance                    =  3.6539E-02
       1 t 0.0000E+00 dt 2.40E-07 flush i/o buffers            12/07/20 19:35:35
       1 t 0.0000E+00 dt 2.40E-07 write d3plot file            12/07/20 19:35:35
    5000 t 1.2010E-03 dt 2.40E-07 flush i/o buffers            12/07/20 19:52:03
    5245 t 1.2599E-03 dt 2.40E-07 write d3plot file            12/07/20 19:52:44
   10000 t 2.4023E-03 dt 2.40E-07 flush i/o buffers            12/07/20 20:08:02
   10489 t 2.5198E-03 dt 2.40E-07 write d3plot file            12/07/20 20:09:18
   15000 t 3.6036E-03 dt 2.40E-07 flush i/o buffers            12/07/20 20:22:28
   15734 t 3.7799E-03 dt 2.40E-07 write d3plot file            12/07/20 20:24:24
   20000 t 4.8048E-03 dt 2.40E-07 flush i/o buffers            12/07/20 20:38:41
   20978 t 5.0398E-03 dt 2.40E-07 write d3plot file            12/07/20 20:41:27
   25000 t 6.0061E-03 dt 2.40E-07 flush i/o buffers            12/07/20 20:54:38
   26223 t 6.2999E-03 dt 2.40E-07 write d3plot file            12/07/20 20:58:07
   30000 t 7.2073E-03 dt 2.40E-07 flush i/o buffers            12/07/20 21:11:01
   31467 t 7.5598E-03 dt 2.40E-07 write d3plot file            12/07/20 21:15:10
   35000 t 8.4086E-03 dt 2.40E-07 flush i/o buffers            12/07/20 21:27:17
   36712 t 8.8199E-03 dt 2.40E-07 write d3plot file            12/07/20 21:31:44
   40000 t 9.6099E-03 dt 2.40E-07 flush i/o buffers            12/07/20 21:43:07
   41956 t 1.0080E-02 dt 2.40E-07 write d3plot file            12/07/20 21:48:38
   45000 t 1.0811E-02 dt 2.40E-07 flush i/o buffers            12/07/20 21:59:24
   47201 t 1.1340E-02 dt 2.40E-07 write d3plot file            12/07/20 22:05:37
   50000 t 1.2012E-02 dt 2.40E-07 flush i/o buffers            12/07/20 22:15:12
   52445 t 1.2600E-02 dt 2.40E-07 write d3plot file            12/07/20 22:22:06
   55000 t 1.3214E-02 dt 2.40E-07 flush i/o buffers            12/07/20 22:30:23
   57690 t 1.3860E-02 dt 2.40E-07 write d3plot file            12/07/20 22:39:02
   60000 t 1.4415E-02 dt 2.40E-07 flush i/o buffers            12/07/20 22:46:38
   62934 t 1.5120E-02 dt 2.40E-07 write d3plot file            12/07/20 22:55:30
   65000 t 1.5616E-02 dt 2.40E-07 flush i/o buffers            12/07/20 23:02:24
   68179 t 1.6380E-02 dt 2.40E-07 write d3plot file            12/07/20 23:12:24
   70000 t 1.6817E-02 dt 2.40E-07 flush i/o buffers            12/07/20 23:18:36
   73423 t 1.7640E-02 dt 2.40E-07 write d3plot file            12/07/20 23:29:14
   75000 t 1.8019E-02 dt 2.40E-07 flush i/o buffers            12/07/20 23:33:57
   78668 t 1.8900E-02 dt 2.40E-07 write d3plot file            12/07/20 23:44:47
   80000 t 1.9220E-02 dt 2.40E-07 flush i/o buffers            12/07/20 23:49:34
   83912 t 2.0160E-02 dt 2.40E-07 write d3plot file            12/08/20 00:00:06
   85000 t 2.0421E-02 dt 2.40E-07 flush i/o buffers            12/08/20 00:04:02
   89157 t 2.1420E-02 dt 2.40E-07 write d3plot file            12/08/20 00:14:30
   90000 t 2.1623E-02 dt 2.40E-07 flush i/o buffers            12/08/20 00:18:03
   94401 t 2.2680E-02 dt 2.40E-07 write d3plot file            12/08/20 00:29:29
   95000 t 2.2824E-02 dt 2.40E-07 flush i/o buffers            12/08/20 00:32:30
   99646 t 2.3940E-02 dt 2.40E-07 write d3plot file            12/08/20 00:43:56
  100000 t 2.4025E-02 dt 2.40E-07 flush i/o buffers            12/08/20 00:46:33
  104890 t 2.5200E-02 dt 2.40E-07 write d3plot file            12/08/20 00:59:07
  105000 t 2.5226E-02 dt 2.40E-07 flush i/o buffers            12/08/20 01:01:03
  110000 t 2.6428E-02 dt 2.40E-07 flush i/o buffers            12/08/20 01:13:55
  110134 t 2.6460E-02 dt 2.40E-07 write d3plot file            12/08/20 01:14:12
  115000 t 2.7629E-02 dt 2.40E-07 flush i/o buffers            12/08/20 01:28:01
  115379 t 2.7720E-02 dt 2.40E-07 write d3plot file            12/08/20 01:28:49
  120000 t 2.8830E-02 dt 2.40E-07 flush i/o buffers            12/08/20 01:42:23
  120623 t 2.8980E-02 dt 2.40E-07 write d3plot file            12/08/20 01:43:46
  125000 t 3.0031E-02 dt 2.40E-07 flush i/o buffers            12/08/20 01:56:23
  125868 t 3.0240E-02 dt 2.40E-07 write d3plot file            12/08/20 01:58:08
  130000 t 3.1233E-02 dt 2.40E-07 flush i/o buffers            12/08/20 02:10:50
  131112 t 3.1500E-02 dt 2.40E-07 write d3plot file            12/08/20 02:13:20
  135000 t 3.2434E-02 dt 2.40E-07 flush i/o buffers            12/08/20 02:25:33
  136357 t 3.2760E-02 dt 2.40E-07 write d3plot file            12/08/20 02:28:34
  140000 t 3.3635E-02 dt 2.40E-07 flush i/o buffers            12/08/20 02:39:21
  141601 t 3.4020E-02 dt 2.40E-07 write d3plot file            12/08/20 02:42:58
  145000 t 3.4836E-02 dt 2.40E-07 flush i/o buffers            12/08/20 02:53:50
  146846 t 3.5280E-02 dt 2.40E-07 write d3plot file            12/08/20 02:57:58
  150000 t 3.6038E-02 dt 2.40E-07 flush i/o buffers            12/08/20 03:08:17
  152090 t 3.6540E-02 dt 2.40E-07 write d3plot file            12/08/20 03:12:30
  155000 t 3.7239E-02 dt 2.40E-07 flush i/o buffers            12/08/20 03:22:19
  157335 t 3.7800E-02 dt 2.40E-07 write d3plot file            12/08/20 03:27:22
  160000 t 3.8440E-02 dt 2.40E-07 flush i/o buffers            12/08/20 03:36:44
  162579 t 3.9060E-02 dt 2.40E-07 write d3plot file            12/08/20 03:42:11
  165000 t 3.9641E-02 dt 2.40E-07 flush i/o buffers            12/08/20 03:48:55
  167824 t 4.0320E-02 dt 2.40E-07 write d3plot file            12/08/20 03:56:56
  170000 t 4.0843E-02 dt 2.40E-07 flush i/o buffers            12/08/20 04:03:23
  173068 t 4.1580E-02 dt 2.40E-07 write d3plot file            12/08/20 04:11:59
  175000 t 4.2044E-02 dt 2.40E-07 flush i/o buffers            12/08/20 04:21:39
  178296 t 4.2840E-02 dt 2.43E-07 write d3plot file            12/08/20 04:32:28
  180000 t 4.3257E-02 dt 2.40E-07 flush i/o buffers            12/08/20 04:37:42
  183450 t 4.4100E-02 dt 2.55E-07 write d3plot file            12/08/20 04:46:40
  185000 t 4.4482E-02 dt 2.40E-07 flush i/o buffers            12/08/20 04:51:58
  188587 t 4.5360E-02 dt 2.55E-07 write d3plot file            12/08/20 05:01:25
  190000 t 4.5706E-02 dt 2.40E-07 flush i/o buffers            12/08/20 05:06:25
  193735 t 4.6620E-02 dt 2.43E-07 write d3plot file            12/08/20 05:16:04
  195000 t 4.6931E-02 dt 2.55E-07 flush i/o buffers            12/08/20 05:20:40
  198877 t 4.7880E-02 dt 2.40E-07 write d3plot file            12/08/20 05:30:21
  200000 t 4.8154E-02 dt 2.40E-07 flush i/o buffers            12/08/20 05:34:36
  204038 t 4.9140E-02 dt 2.40E-07 write d3plot file            12/08/20 05:44:57
  205000 t 4.9375E-02 dt 2.40E-07 flush i/o buffers            12/08/20 05:48:57
  209199 t 5.0400E-02 dt 2.40E-07 write d3plot file            12/08/20 05:59:30
  210000 t 5.0596E-02 dt 2.55E-07 flush i/o buffers            12/08/20 06:03:06
  214358 t 5.1660E-02 dt 2.40E-07 write d3plot file            12/08/20 06:13:36
  215000 t 5.1817E-02 dt 2.40E-07 flush i/o buffers            12/08/20 06:17:01
  219509 t 5.2920E-02 dt 2.40E-07 write d3plot file            12/08/20 06:28:09
  220000 t 5.3040E-02 dt 2.40E-07 flush i/o buffers            12/08/20 06:31:17
  224668 t 5.4180E-02 dt 2.55E-07 write d3plot file            12/08/20 06:45:06
  225000 t 5.4261E-02 dt 2.40E-07 flush i/o buffers            12/08/20 06:45:47
  229821 t 5.5440E-02 dt 2.40E-07 write d3plot file            12/08/20 06:57:13
  230000 t 5.5483E-02 dt 2.40E-07 flush i/o buffers            12/08/20 06:59:43
  234979 t 5.6700E-02 dt 2.40E-07 write d3plot file            12/08/20 07:11:49
  235000 t 5.6705E-02 dt 2.55E-07 flush i/o buffers            12/08/20 07:14:00
  240000 t 5.7925E-02 dt 2.43E-07 flush i/o buffers            12/08/20 07:25:52
  240144 t 5.7960E-02 dt 2.55E-07 write d3plot file            12/08/20 07:28:11
  245000 t 5.9147E-02 dt 2.55E-07 flush i/o buffers            12/08/20 07:40:02
  245298 t 5.9220E-02 dt 2.40E-07 write d3plot file            12/08/20 07:40:37
  250000 t 6.0369E-02 dt 2.40E-07 flush i/o buffers            12/08/20 07:53:48
  250456 t 6.0480E-02 dt 2.40E-07 write d3plot file            12/08/20 07:54:43
  255000 t 6.1589E-02 dt 2.43E-07 flush i/o buffers            12/08/20 08:07:55
  255616 t 6.1740E-02 dt 2.40E-07 write d3plot file            12/08/20 08:11:16
  260000 t 6.2809E-02 dt 2.43E-07 flush i/o buffers            12/08/20 08:21:56
  260779 t 6.3000E-02 dt 2.40E-07 write d3plot file            12/08/20 08:23:23
  265000 t 6.4030E-02 dt 2.40E-07 flush i/o buffers            12/08/20 08:35:51
  265939 t 6.4260E-02 dt 2.40E-07 write d3plot file            12/08/20 08:37:49
  270000 t 6.5252E-02 dt 2.40E-07 flush i/o buffers            12/08/20 08:49:56
  271095 t 6.5520E-02 dt 2.40E-07 write d3plot file            12/08/20 08:52:09
  275000 t 6.6472E-02 dt 2.40E-07 flush i/o buffers            12/08/20 09:04:38
  276263 t 6.6780E-02 dt 2.43E-07 write d3plot file            12/08/20 09:09:31
  280000 t 6.7692E-02 dt 2.40E-07 flush i/o buffers            12/08/20 09:19:36
  281424 t 6.8040E-02 dt 2.40E-07 write d3plot file            12/08/20 09:22:46
  285000 t 6.8912E-02 dt 2.40E-07 flush i/o buffers            12/08/20 09:33:42
  286595 t 6.9300E-02 dt 2.40E-07 write d3plot file            12/08/20 09:38:56
  290000 t 7.0131E-02 dt 2.43E-07 flush i/o buffers            12/08/20 09:48:26
  291761 t 7.0560E-02 dt 2.55E-07 write d3plot file            12/08/20 09:54:05
  295000 t 7.1351E-02 dt 2.43E-07 flush i/o buffers            12/08/20 10:03:11
  296919 t 7.1820E-02 dt 2.55E-07 write d3plot file            12/08/20 10:09:07
  300000 t 7.2572E-02 dt 2.40E-07 flush i/o buffers            12/08/20 10:17:49
  302083 t 7.3080E-02 dt 2.40E-07 write d3plot file            12/08/20 10:24:07
  305000 t 7.3794E-02 dt 2.40E-07 flush i/o buffers            12/08/20 10:32:26
  307244 t 7.4340E-02 dt 2.55E-07 write d3plot file            12/08/20 10:39:06
  310000 t 7.5012E-02 dt 2.40E-07 flush i/o buffers            12/08/20 10:46:59
  312417 t 7.5600E-02 dt 2.40E-07 write d3plot file            12/08/20 10:52:44
  315000 t 7.6232E-02 dt 2.40E-07 flush i/o buffers            12/08/20 11:01:36
  317572 t 7.6860E-02 dt 2.43E-07 write d3plot file            12/08/20 11:08:58
  320000 t 7.7453E-02 dt 2.40E-07 flush i/o buffers            12/08/20 11:15:00
  322736 t 7.8120E-02 dt 2.55E-07 write d3plot file            12/08/20 11:24:05
  325000 t 7.8673E-02 dt 2.55E-07 flush i/o buffers            12/08/20 11:28:36
  327896 t 7.9380E-02 dt 2.55E-07 write d3plot file            12/08/20 11:36:02
  330000 t 7.9893E-02 dt 2.40E-07 flush i/o buffers            12/08/20 11:41:38
  333074 t 8.0640E-02 dt 2.40E-07 write d3plot file            12/08/20 11:49:02
  335000 t 8.1111E-02 dt 2.40E-07 flush i/o buffers            12/08/20 11:54:37
  338243 t 8.1900E-02 dt 2.40E-07 write d3plot file            12/08/20 12:02:56
  340000 t 8.2329E-02 dt 2.40E-07 flush i/o buffers            12/08/20 12:09:13
  343418 t 8.3160E-02 dt 2.43E-07 write d3plot file            12/08/20 12:19:11
  345000 t 8.3546E-02 dt 2.43E-07 flush i/o buffers            12/08/20 12:25:05
  348580 t 8.4420E-02 dt 2.55E-07 write d3plot file            12/08/20 12:33:49
  350000 t 8.4766E-02 dt 2.43E-07 flush i/o buffers            12/08/20 12:38:12
  353750 t 8.5680E-02 dt 2.40E-07 write d3plot file            12/08/20 12:47:05
  355000 t 8.5986E-02 dt 2.43E-07 flush i/o buffers            12/08/20 12:51:00
  358921 t 8.6940E-02 dt 2.40E-07 write d3plot file            12/08/20 13:01:49
  360000 t 8.7204E-02 dt 2.40E-07 flush i/o buffers            12/08/20 13:06:27
  364089 t 8.8200E-02 dt 2.40E-07 write d3plot file            12/08/20 13:18:46
  365000 t 8.8422E-02 dt 2.55E-07 flush i/o buffers            12/08/20 13:20:54
  369260 t 8.9460E-02 dt 2.43E-07 write d3plot file            12/08/20 13:32:19
  370000 t 8.9640E-02 dt 2.40E-07 flush i/o buffers            12/08/20 13:35:33
  374431 t 9.0720E-02 dt 2.40E-07 write d3plot file            12/08/20 13:48:56
  375000 t 9.0858E-02 dt 2.40E-07 flush i/o buffers            12/08/20 13:50:19
  379595 t 9.1980E-02 dt 2.40E-07 write d3plot file            12/08/20 14:03:44
  380000 t 9.2079E-02 dt 2.40E-07 flush i/o buffers            12/08/20 14:04:45
  384767 t 9.3240E-02 dt 2.55E-07 write d3plot file            12/08/20 14:18:46
  385000 t 9.3296E-02 dt 2.55E-07 flush i/o buffers            12/08/20 14:19:22
  389936 t 9.4500E-02 dt 2.40E-07 write d3plot file            12/08/20 14:32:05
  390000 t 9.4515E-02 dt 2.40E-07 flush i/o buffers            12/08/20 14:33:39
  395000 t 9.5733E-02 dt 2.55E-07 flush i/o buffers            12/08/20 14:46:14
  395105 t 9.5760E-02 dt 2.55E-07 write d3plot file            12/08/20 14:46:30
  400000 t 9.6954E-02 dt 2.55E-07 flush i/o buffers            12/08/20 15:00:44
  400271 t 9.7020E-02 dt 2.55E-07 write d3plot file            12/08/20 15:02:49
  405000 t 9.8173E-02 dt 2.40E-07 flush i/o buffers            12/08/20 15:15:08
  405442 t 9.8280E-02 dt 2.40E-07 write d3plot file            12/08/20 15:16:10
  410000 t 9.9393E-02 dt 2.40E-07 flush i/o buffers            12/08/20 15:29:37
  410603 t 9.9540E-02 dt 2.40E-07 write d3plot file            12/08/20 15:31:01
  415000 t 1.0061E-01 dt 2.40E-07 flush i/o buffers            12/08/20 15:44:05
  415781 t 1.0080E-01 dt 2.40E-07 write d3plot file            12/08/20 15:45:52
  420000 t 1.0183E-01 dt 2.43E-07 flush i/o buffers            12/08/20 15:58:36
  420955 t 1.0206E-01 dt 2.40E-07 write d3plot file            12/08/20 16:02:18
  425000 t 1.0305E-01 dt 2.40E-07 flush i/o buffers            12/08/20 16:13:03
  426120 t 1.0332E-01 dt 2.40E-07 write d3plot file            12/08/20 16:15:41
  430000 t 1.0426E-01 dt 2.40E-07 flush i/o buffers            12/08/20 16:27:20
  431299 t 1.0458E-01 dt 2.55E-07 write d3plot file            12/08/20 16:30:22
  435000 t 1.0548E-01 dt 2.43E-07 flush i/o buffers            12/08/20 16:41:50
  436474 t 1.0584E-01 dt 2.40E-07 write d3plot file            12/08/20 16:45:10
  440000 t 1.0670E-01 dt 2.55E-07 flush i/o buffers            12/08/20 16:56:15
  441644 t 1.0710E-01 dt 2.40E-07 write d3plot file            12/08/20 17:01:25
  445000 t 1.0792E-01 dt 2.40E-07 flush i/o buffers            12/08/20 17:10:45
  446817 t 1.0836E-01 dt 2.40E-07 write d3plot file            12/08/20 17:16:05
  450000 t 1.0914E-01 dt 2.55E-07 flush i/o buffers            12/08/20 17:24:46
  451977 t 1.0962E-01 dt 2.40E-07 write d3plot file            12/08/20 17:29:22
  455000 t 1.1036E-01 dt 2.40E-07 flush i/o buffers            12/08/20 17:39:35
  457151 t 1.1088E-01 dt 2.43E-07 write d3plot file            12/08/20 17:44:32
  460000 t 1.1158E-01 dt 2.43E-07 flush i/o buffers            12/08/20 17:54:13
  462309 t 1.1214E-01 dt 2.55E-07 write d3plot file            12/08/20 17:59:39
  465000 t 1.1280E-01 dt 2.55E-07 flush i/o buffers            12/08/20 18:09:08
  467480 t 1.1340E-01 dt 2.40E-07 write d3plot file            12/08/20 18:14:52
  470000 t 1.1401E-01 dt 2.55E-07 flush i/o buffers            12/08/20 18:22:05
  472648 t 1.1466E-01 dt 2.55E-07 write d3plot file            12/08/20 18:31:15
  475000 t 1.1523E-01 dt 2.40E-07 flush i/o buffers            12/08/20 18:36:41
  477833 t 1.1592E-01 dt 2.40E-07 write d3plot file            12/08/20 18:46:09
  480000 t 1.1645E-01 dt 2.40E-07 flush i/o buffers            12/08/20 18:51:11
  482997 t 1.1718E-01 dt 2.40E-07 write d3plot file            12/08/20 19:00:54
  485000 t 1.1767E-01 dt 2.40E-07 flush i/o buffers            12/08/20 19:05:31
  488174 t 1.1844E-01 dt 2.40E-07 write d3plot file            12/08/20 19:14:18
  490000 t 1.1888E-01 dt 2.40E-07 flush i/o buffers            12/08/20 19:20:00
  493345 t 1.1970E-01 dt 2.40E-07 write d3plot file            12/08/20 19:30:29
  495000 t 1.2010E-01 dt 2.40E-07 flush i/o buffers            12/08/20 19:34:21
  498530 t 1.2096E-01 dt 2.40E-07 write d3plot file            12/08/20 19:45:27
  500000 t 1.2132E-01 dt 2.55E-07 flush i/o buffers            12/08/20 19:49:27
  503706 t 1.2222E-01 dt 2.43E-07 write d3plot file            12/08/20 20:01:19
  505000 t 1.2253E-01 dt 2.55E-07 flush i/o buffers            12/08/20 20:06:08
  508889 t 1.2348E-01 dt 2.40E-07 write d3plot file            12/08/20 20:18:09
  510000 t 1.2375E-01 dt 2.55E-07 flush i/o buffers            12/08/20 20:22:34
  514068 t 1.2474E-01 dt 2.43E-07 write d3plot file            12/08/20 20:34:55
  515000 t 1.2497E-01 dt 2.40E-07 flush i/o buffers            12/08/20 20:38:46
  519236 t 1.2600E-01 dt 2.40E-07 write d3plot file            12/08/20 20:51:35
  520000 t 1.2618E-01 dt 2.55E-07 flush i/o buffers            12/08/20 20:55:02
  524407 t 1.2726E-01 dt 2.43E-07 write d3plot file            12/08/20 21:08:16
  525000 t 1.2740E-01 dt 2.40E-07 flush i/o buffers            12/08/20 21:11:17
  529590 t 1.2852E-01 dt 2.40E-07 write d3plot file            12/08/20 21:25:00
  530000 t 1.2862E-01 dt 2.55E-07 flush i/o buffers            12/08/20 21:27:28
  534757 t 1.2978E-01 dt 2.43E-07 write d3plot file            12/08/20 21:41:38
  535000 t 1.2984E-01 dt 2.40E-07 flush i/o buffers            12/08/20 21:43:35
  539925 t 1.3104E-01 dt 2.40E-07 write d3plot file            12/08/20 21:58:07
  540000 t 1.3106E-01 dt 2.40E-07 flush i/o buffers            12/08/20 21:59:42
  545000 t 1.3228E-01 dt 2.40E-07 flush i/o buffers            12/08/20 22:14:24
  545093 t 1.3230E-01 dt 2.55E-07 write d3plot file            12/08/20 22:14:40
  550000 t 1.3350E-01 dt 2.40E-07 flush i/o buffers            12/08/20 22:30:22
  550266 t 1.3356E-01 dt 2.40E-07 write d3plot file            12/08/20 22:31:05
  555000 t 1.3472E-01 dt 2.40E-07 flush i/o buffers            12/08/20 22:46:26
  555430 t 1.3482E-01 dt 2.40E-07 write d3plot file            12/08/20 22:47:34
  560000 t 1.3593E-01 dt 2.43E-07 flush i/o buffers            12/08/20 23:01:15
  560598 t 1.3608E-01 dt 2.40E-07 write d3plot file            12/08/20 23:02:27
  565000 t 1.3715E-01 dt 2.40E-07 flush i/o buffers            12/08/20 23:14:35
  565770 t 1.3734E-01 dt 2.55E-07 write d3plot file            12/08/20 23:16:09
  570000 t 1.3837E-01 dt 2.55E-07 flush i/o buffers            12/08/20 23:27:42
  570952 t 1.3860E-01 dt 2.55E-07 write d3plot file            12/08/20 23:29:41
  575000 t 1.3959E-01 dt 2.43E-07 flush i/o buffers            12/08/20 23:41:10
  576113 t 1.3986E-01 dt 2.40E-07 write d3plot file            12/08/20 23:43:25
  580000 t 1.4081E-01 dt 2.55E-07 flush i/o buffers            12/08/20 23:54:41
  581279 t 1.4112E-01 dt 2.40E-07 write d3plot file            12/08/20 23:57:18
  585000 t 1.4203E-01 dt 2.40E-07 flush i/o buffers            12/09/20 00:08:11
  586444 t 1.4238E-01 dt 2.40E-07 write d3plot file            12/09/20 00:11:05
  590000 t 1.4325E-01 dt 2.40E-07 flush i/o buffers            12/09/20 00:21:29
  591619 t 1.4364E-01 dt 2.43E-07 write d3plot file            12/09/20 00:24:45
  595000 t 1.4446E-01 dt 2.40E-07 flush i/o buffers            12/09/20 00:34:51
  596790 t 1.4490E-01 dt 2.40E-07 write d3plot file            12/09/20 00:38:26
  600000 t 1.4568E-01 dt 2.43E-07 flush i/o buffers            12/09/20 00:48:20
  601970 t 1.4616E-01 dt 2.40E-07 write d3plot file            12/09/20 00:52:19
  605000 t 1.4690E-01 dt 2.55E-07 flush i/o buffers            12/09/20 01:01:49
  607144 t 1.4742E-01 dt 2.40E-07 write d3plot file            12/09/20 01:06:08
  610000 t 1.4811E-01 dt 2.40E-07 flush i/o buffers            12/09/20 01:15:01
  612318 t 1.4868E-01 dt 2.40E-07 write d3plot file            12/09/20 01:19:43
  615000 t 1.4933E-01 dt 2.40E-07 flush i/o buffers            12/09/20 01:28:33
  617489 t 1.4994E-01 dt 2.40E-07 write d3plot file            12/09/20 01:33:36
  620000 t 1.5055E-01 dt 2.40E-07 flush i/o buffers            12/09/20 01:40:14
  622663 t 1.5120E-01 dt 2.40E-07 write d3plot file            12/09/20 01:47:24
  625000 t 1.5177E-01 dt 2.40E-07 flush i/o buffers            12/09/20 01:53:47
  627832 t 1.5246E-01 dt 2.43E-07 write d3plot file            12/09/20 02:01:18
  630000 t 1.5299E-01 dt 2.40E-07 flush i/o buffers            12/09/20 02:07:26
dyna护栏
提示的警告是接触中有初始穿透,不过计算是算了一段时间以后停的,所以估计不是初始穿透导致的模型无法计算问题,应该是模型的其他设置存在问题。
2020年12月16日
已采纳 评论 1 点赞 2
天空1221
你好,请问这个问题解决了吗?我也有同样的问题
2021年9月20日
TechmanLXS
初始穿透本质上就是模型里网格厚度设置不合适,导致物理意义上有穿透,最正确的方法是调模型
2020年12月15日
评论 3 点赞
