lsdyna R10版本隐式计算无法计算?
浏览:1602 回答:3
 Beginning of keyword reader                                   12/27/20 15:35:15
 Memory required to process keyword     :      473401
 *** Warning 30365 (INI+365)
     Implicit solver does not support LSTC_MEMORY=auto.
     The option is turned off
 input of data is completed
 initial kinetic energy = 0.00000000E+00
 The LS-DYNA time step size should not exceed     2.987E-04
 to avoid contact instabilities.  If the step size is
 bigger then scale the penalty of the offending surface.
 Memory required for implicit solution  :      2916633
 termination time                  = 1.000E+00
 Memory required to begin solution      :    2917K
 Linear Alg dynamically allocated memory:      51K
 Additional dynamically allocated memory:    4675K
                                   Total:    7642K
 initialization completed
 calculation with mass scaling for minimum dt
    added mass   =   0.0000E+00
    physical mass=   1.0403E-01
    ratio        =   0.0000E+00
       1 t 0.0000E+00 dt 1.00E-03 flush i/o buffers            12/27/20 15:35:17
       1 t 0.0000E+00 dt 1.00E-03 write d3plot file            12/27/20 15:35:17
 BEGIN implicit statics  step      1 t= 1.0000E-03             12/27/20 15:35:17
     ==            IMPLICIT USAGE ALERT            ==
     == Memory Management for Implicit has changed ==
     == after R10.  Please use:                    ==
     ==       memory=     4M                       ==
forrtl: severe (168): Program Exception - illegal instruction
Image              PC                Routine            Line        Source
ls-dyna_smp_d_R11  00007FF79BC29552  Unknown               Unknown  Unknown
ls-dyna_smp_d_R11  00007FF79B638BE4  Unknown               Unknown  Unknown
ls-dyna_smp_d_R11  00007FF79B3860D8  Unknown               Unknown  Unknown
ls-dyna_smp_d_R11  00007FF79B2B3258  Unknown               Unknown  Unknown
ls-dyna_smp_d_R11  00007FF798E73BE7  Unknown               Unknown  Unknown
ls-dyna_smp_d_R11  00007FF79A90F821  Unknown               Unknown  Unknown
E:\five\six>
出现了隐式用法警报,请问是电脑内存的问题吗?还是什么问题?该如何解决?
从前_7431
您好,请问您解决了吗
2023年11月10日
云上_CAE
我没用过r10.r11应该可以
2021年1月4日
