ANSYS使用结构模块时出错? 50
浏览:1279
电脑安装的Linux版本的ANSYS,使用fluent很正常,没有问题,但是使用mechanical模块求解时就报错,An error occurred while starting the solver module. Please refer to the Troubleshooting section in the ANSYS Mechanical User Guide.在控制台出现提示:/ansys_inc/v192/aisol/../commonfiles/CPython/2_7_13/linux64/Release/python/runprtuon:line 2:dirname:command not found
