Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
壳体结构冲击模拟 壁厚为什么会减小?
浏览: 3591 回答: 1
Dear all,
I'm now simulating tube crushing with Abaqus/Explicit. The tube is meshed with shell elements, and general contact is used for contact. As the mesh goes finer, the thickness of elements reduces and there's a warning message as follows:
In step 1, some facet thicknesses for general contact were reduced
            from the parent element or specified values due to a large
            thickness compared to facet dimensions.  The most significant
            thickness scaling factor was 0.69815 for a facet on parent element
            53801 of instance QQQQ-2.  An element set named
            "WarnElemGContThickReduce" has been created to locate the regions
            of reduced thickness.
I know that such thickness reduction is required by the contact simulation, but can anyone give some comments on to what extent such reduction will influence the final results? and is it possible to know the amount of thickness reduction for each element whose thickness has been reduced. (As the warning message only gives the most significant reduction value). can you gei me some adbice  . I attempt to great contact pair and transform to soild module but the mesh hard to draw .
Many thanks and kindly regards,
XIAO.K
全部回答 (1)
郑钧 Adam 2021年1月7日
Thickness reduction is a common issue when you use shell element in Explicit solver with general contact. When self-contact among shell element is detected by general contact, system will automatically reduce section thickness in order to avoid abnoraml physical phenomenon.
This problem can be solved through exclude self-contact of specific part and use keyword to cancel thickness reduction. Please refer to my course for more information about how to avoid thickness reduction when use shell element In Explicit solver.
https://www.jishulink.com/college/video/c15821
2021年1月7日
评论 点赞 2
相似问题
查看全部
  • 壳体结构冲击模拟 壁厚为什么会减小? 暂无回答
    Dear all, I'm now simulating tube crushing with Abaqus/Explicit. The tube is meshed with shell elements, and general contact is used for contact. As the mesh goes finer, the thickness of elements redu
  • 这个warning什么意思,怎么解决? 5个回答
    some facet thicknesses for general contact were reduced from the parent element or specified values due to a large thickness compared to fac
  • abaqus动力显式模拟挤压,在运行一定过程,网格畸变过大,报错,想了解如何解决? 已解决
    报错信息为 The elements in element set ErrElemZeroALEMass-Step1 have zero or negative mass. There are a total of 7 excessively distorted elements The elements contained in element set ErrElemExcessDistorti
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
公路钢筋混凝土及预应力混凝土桥涵设计规范解决方案
敦樸DUNPU 敦樸DUNPU
免费
慧加新规范解决方案详解之大跨连续弯梁桥精细化分析(7DOF)
敦樸DUNPU 敦樸DUNPU
免费
混合弯头的流体流动与传热
混合弯头的流体流动与传热
CFD流 CFD流
免费
Abaqus子程序安装教程 Abaqus6.14.2+VS2013+IVF2013(附带安装包)
二十 二十
免费
北京华盛扬科技 北京华盛扬科技
¥9.9
Msc Apex For Aerospace Applications Idealization a
MSC Apex
免费
超大规模芯片电源完整性签核平台RedHawk-SC应用分享
Ansys中国 Ansys中国
免费
