Hypermesh #error 3840怎么处理?
A fatal error has been detected during input processing:
*** ERROR # 3840 ***
The eigenvalue solution for solving CMS modes has failed to obtain
the desired modes.
dimension of eigen problem = 24
obtained number of modes = 0
The failure is likely to be caused by misplaced interface nodes or
ill-conditioned eigen problem. Please check the model and rerun
the problem. If you cannot resolve this error, please send the input
model to ossupport for debugging.
这个ossupport是什么啊
全部回答 (1)
模型方便发过来我看看
2021年1月21日
CAE追梦者 2021年1月21日
