属性已经添加,还是出现找不到element,哪位大神麻烦帮个忙?
浏览:1264 回答:1
Preserving existing .out file as:
D:/WorkProgram/Hypermesh-gongzuomulu/TA899-22AL-091026_001.out
Preserving existing .stat file as:
D:/WorkProgram/Hypermesh-gongzuomulu/TA899-22AL-091026_001.stat
 **                    Altair OptiStruct(TM) 2019.1                    **
 **             Advanced Engineering Analysis, Design and              **
 **        Optimization Software from Altair Engineering, Inc.         **
 **             Windows 10  (Build 9200)  DESKTOP-KF7RSDK              **
 **         12 CPU:  Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz         **
 **                    7560 MB RAM,  16161 MB swap                     **
 **                        64bit Integer Build                         **
 ** Build: 0972633_9633191_Ce64RBW68UH14M:162557-100  2004004000000004 **
 **  COPYRIGHT (C) 1996-2019                 Altair Engineering, Inc.  **
 ** All Rights Reserved.  Copyright notice does not imply publication. **
 **         Contains trade secrets of Altair Engineering, Inc.         **
 ** Decompilation or disassembly of this software strictly prohibited. **
 *** ERROR #  61 ***
 No elements found in the input data.
 A fatal error has been detected during input processing:
  *** ERROR #  61 ***
 ==== End of solver screen output ====
 ==== OptiStruct Job completed ====
风轻流吟
提交的计算文件不包含单元,要么是你建模没有单元,要么就是你模板用的不对,单元类型不对,方便的话上传下你的fem文件
2021年2月18日
已采纳 评论 点赞 1
