请教一个ANSYS的循环语句问题,有命令请各位帮忙检查一下? 100
浏览:1369 回答:1
帮忙看一下命令里的感叹号中间的语句,为什么符合if条件的时候,这个语句无法取消选中相应的线呢?是不是语句写的有问题呢
*DO,jj,-1,1,2
*DO,ii,1,120,1
wplane,-1,9.25*jj,-ycor(gbbh(ii)),xcor(gbbh(ii)),(9.25+1)*jj,-ycor(gbbh(ii)),xcor(gbbh(ii)),9.25*jj,-ycor(gbbh(ii))+sink(gbbh(ii)),xcor(gbbh(ii))+cosk(gbbh(ii))
cswpla,11,0
csys,11
*if,gbbh(ii),le,20,then
fj=0.04
*else
fj=0.036
*endif
lsel,s,loc,z,0,0.0001,,1
lsel,r,loc,x,-4,4
lsel,u,length,,0.3,0.35
*DO,aa,1,10,1
*if,gbbh(ii),eq,halfu(aa),then
ksel,s,kp,,(halfu(aa)-1)*60+7+jj*9600,(halfu(aa)-1)*60+20+jj*9600
lslk,u
*cycle
*elseif,gbbh(ii),eq,halfd(aa)
ksel,s,kp,,(halfd(aa)-1)*60+1+jj*9600,(halfd(aa)-1)*60+4+jj*9600
ksel,a,kp,,(halfd(aa)-1)*60+23+jj*9600,(halfd(aa)-1)*60+32+jj*9600
lslk,u
*cycle
*else
*cycle
*endif
*enddo
cm,gbline,line
al,gbline
allsel,all
wpcsys,,0
csys,0
*enddo
*enddo
synjam
是if语句有问题吗 还是啥 求解答
2021年3月9日
