Adams报错是啥原因啊? 20
浏览:1900 回答:1
就是做振动分析的,测试以后报错QR: The eigen solution produced one or more defective eigen values. For these eigen values generalized eigen vectors will be used in the solution. This generally indicates a problem with the model (zero stiffness, free body, invalid constraint).
风轻流吟
应该是你约束有问题或者约束不足导致的
2021年3月22日
