为什么降温法模拟钢绞线(桁架单元)后处理云图中会这样?
浏览:1848 回答:2
Solver problem. Zero pivot when processing D.O.F. 2 of 4 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_1_1.
Solver problem. Zero pivot when processing D.O.F. 1 of 6 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_1_2_1.
Solver problem. Zero pivot when processing D.O.F. 2 of 6 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_2_1.
Solver problem. Zero pivot when processing D.O.F. 3 of 4 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_1_1_2_1.
Solver problem. Zero pivot when processing D.O.F. 1 of 6 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_1_3_1.
Solver problem. Zero pivot when processing D.O.F. 2 of 6 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_3_1.
Solver problem. Zero pivot when processing D.O.F. 3 of 4 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_1_1_3_1.
Solver problem. Zero pivot when processing D.O.F. 1 of 5 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_1_1_1_4_1.
Solver problem. Zero pivot when processing D.O.F. 2 of 5 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_2_1_1_4_1.
Solver problem. Zero pivot when processing D.O.F. 3 of 3 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_1_1_4_1.
为什么降温法模拟钢绞线(桁架单元)后处理云图中会这样?的图2
SnowWave02
是不是杆单元约束不够?杆单元没法固支的,只能约束平动
2021年4月3日
