求求大佬了在abaqus中遇到了此问题怎么办啊? 50
浏览:2923 回答:2
The rigid bodies with the reference nodes contained in node set ErrNodeRefNodeNoRot1Axis have atleast one axis about which the rotary inertia magnitude is zero, and the rigid bodies have atleast one rotational degree of freedom which is unconstrained. Either rotary inertia must be defined at the reference nodes or all of the rotational degrees of freedom at the reference nodes must be constrained. See the status file for further details.
寒江雪_123
约束rp的旋转自由度或者设置相应的转动惯量。
2021年5月10日
评论 点赞 1
北望逸尘
模型的问题
2021年5月9日
