顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
Abaqus壳单元分析运行终止,报错Too many attempts made for ? 50
浏览: 4510 回答: 4
用hypermesh抽取中面划分壳单元后,导入到abaqus中设置进行分析,分析终止只报错Too many attempts made for this increment。
警告内容:
For *tie pair (assembly_channel-tie-assembly_base-tie), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Slave node 80 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 352 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 440 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 848 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 1259 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 1403 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 1943 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 1984 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 2601 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 2677 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
Slave node 3302 instance part-1-1 will not be tied to the master surface assembly_base-tie. The distance from the master surface is greater than the position tolerance value.
378 nodes are either missing intersection with their respective master surface or are outside the adjust zone. The nodes have been identified in node set WarnNodeMissMasterIntersect.
103 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
202 elements are curved/warped. The angle subtended between the average element normal and a nodal normal exceeds 10 degrees. Mesh refinement is recommended. The elements have been identified in element set WarnElemWarped.
没做过abaqus壳单元分析,还请指教
ABAQUS hypermesh
全部回答 (4)
北望逸尘 2021年5月14日
这就是模型的问题,需要调试才可以
2021年5月14日
评论 点赞 3
阿瓦隆号 2021年5月14日
接触设置不合理,单元过度扭曲。可能是adjust打开了。建议系统看下软件的接触章节
2021年5月14日
评论 点赞 3
1点 2021年5月14日
从报错提示上看应该是Tie接触的问题,有可能是过约束,可以调整一下接触,比如先调整一下主从面关系
2021年5月14日
评论 点赞 2
L_2194 2021年5月21日
警告对求解是否成功没影响,单元质量差会影响结果准确性;初始增量步设置为0.01求解报错,改为0.1后求解成功。
2021年5月21日
相似问题
查看全部
  • 求指导,关于Tie,The distance from the master surface is greater than..... 5个回答
    遇见了下面的问题,苦思冥想了好久也没有解决。ABAQUS 绑定约束 出现以下问题: Slave surface assembly_set-2_cns_ is a node-based surface used with surface to surface approach. In order to obtain improved stress accuracy with this approac
  • 水下井口局部有限元分析模型报错及警告问题求解? 暂无回答
    用ABAQUS进行分析时,总是算了一下就出错,看了一下warning和Error主要是这些问题,求问怎么解决? 1.5624 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncor
  • 请问一下,2个小问题??? 4个回答
    1:在后处理中,做出来的荷载--挠度 曲线,应力--应变曲线,最后都保存在哪个文件里面???下次可以直接打开,看到那些曲线 2:在data check 里面,那些警告信息都保存在哪里面???怎么查看模型中哪些是被警告的??? 就像这样的警告 Slave node 77 instance c-1 will not be tied to the master surface assembly__pic
推荐阅读
ABAQUS中级教程合集--搞定滞回曲线
1点 1点
¥299
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
Mathcad基本操作
Mathcad基本操作
HYT HYT
¥89
后排座椅和安全带固定点强度分析
后排座椅和安全带固定点强度分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥80
Altair基于仿真驱动的制造工艺解决方案
ALTAIR ALTAIR
免费
workbench纯六面体网格划分
workbench纯六面体网格划分
八号楼停水 八号楼停水
¥100
Altair SimSolid 求解精度控制和对标网络研讨会
ALTAIR ALTAIR
免费
ABAQUS热切割数值模拟
ABAQUS热切割数值模拟
hitliuyong hitliuyong
¥99
Python面向对象的有限元编程
Python面向对象的有限元编程
weilai00 weilai00
¥60
HBK声学测量基础
HBK声学测量基础
HBK声学与振动 HBK声学与振动
免费
基于ABAQUS和ANSYS接触分析
基于ABAQUS和ANSYS接触分析
宁博士CAE团队 宁博士CAE团队
免费
I-04稳态流:后台阶《STAR CCM+官方案例视频教程》
云之树 云之树
免费
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
hypermesh_dyna小车碰撞护栏(无声)
吴文泽 吴文泽
¥18
使用已标定的车辆动力学模型提升开发效率
使用已标定的车辆动力学模型提升开发效率
VI-grade中国 VI-grade中国
免费
solidworks 2016基础操作入门到精通
新征程学院 新征程学院
免费
热力学理论入门基础(上)
热力学理论入门基础(上)
引垂思汀 引垂思汀
¥30
Apex助力船舶海洋工程智能化快速建模
Apex助力船舶海洋工程智能化快速建模
海克斯康设计与仿真 海克斯康设计与仿真
免费
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
