meesag文件?
浏览:2392 回答:1
********  notice  ********  notice  ********  notice  ********
 contracting memory to           1 beginning of keyword reader
 expanding   memory to       21002
 expanding   memory to       43072
 expanding   memory to       97144
 expanding   memory to      135394
 expanding   memory to      212386
 expanding   memory to      235408
 expanding   memory to      258368
 expanding   memory to      286995
 expanding   memory to      332996
 expanding   memory to      354302
 Memory required to process keyword     :       354302
 contracting memory to           1 end of keyword reader
 LS-DYNA will perform a structural only analysis
 LS-DYNA user input
                         ls-dyna ls971s.53450 R4.2.1  date 06/08/2009
 expanding   memory to        3249 material, node and element data
 expanding   memory to        3338 material properties
 expanding   memory to       21351 element data
 expanding   memory to       29518 gradient of damage data
 expanding   memory to      103717 user control for contact interfaces
 expanding   memory to      103724 for boundary cond. vectorization
 expanding   memory to      105113 arbitrary element numbering input
 expanding   memory to      107358 spc cards
 expanding   memory to      261728 process element material data
 expanding   memory to      263729 load curve data
 contracting memory to      261930 regularize time history data
 contracting memory to      261730 rigidwall definitions
 expanding   memory to      264332 nodal constraint sets
 expanding   memory to      277359 contact interfaces
 expanding   memory to      283513 implicit contact 1
 expanding   memory to      287547 implicit contact 2
 contracting memory to      283770 contact segment data 1
 expanding   memory to      285424 contact segment data 2
 expanding   memory to      298853 contact segment data 3
 expanding   memory to      377861 contact definition
 expanding   memory to      386255 rigid body
 contracting memory to      380625 contact friction
 expanding   memory to      385593 joints
 contracting memory to      385593 shell solid interfaces
 contracting memory to      385593 accelerometers
 expanding   memory to      385693 rigid bodies for disp. termination
 contracting memory to      385693 transformation to move nodes
 expanding   memory to      385699 thermal expansion 0
 expanding   memory to      385705 flexible body 2
 contracting memory to      385705 implicit joints
 expanding   memory to      393385 initialization phase
 *** Error beam            1 has zero area
 *** Error beam            2 has zero area
 *** Error beam            3 has zero area
 *** Error beam            4 has zero area
 *** Error beam            5 has zero area
 *** Error beam            6 has zero area
 *** Error beam            7 has zero area
 *** Error beam            8 has zero area
 *** Error beam            9 has zero area
 *** Error beam           10 has zero area
 *** Error beam           11 has zero area
 *** Error beam           12 has zero area
 *** Error beam           13 has zero area
 *** Error beam           14 has zero area
 *** Error beam           15 has zero area
 *** Error beam           16 has zero area
 *** Error beam           17 has zero area
 *** Error beam           18 has zero area
 *** Error beam           19 has zero area
 *** Error beam           20 has zero area
 *** Error beam           21 has zero area
 *** Error beam           22 has zero area
 *** Error beam           23 has zero area
 *** Error beam           24 has zero area
 *** Error beam           25 has zero area
 *** Error beam           26 has zero area
 *** Error beam           27 has zero area
 *** Error beam           28 has zero area
 *** Error beam           29 has zero area
 *** Error beam           30 has zero area
 *** Error beam           31 has zero area
 *** Error beam           32 has zero area
 *** Error beam           33 has zero area
 *** Error beam           34 has zero area
 *** Error beam           35 has zero area
 *** Error beam           36 has zero area
 *** Error beam           37 has zero area
 *** Error beam           38 has zero area
 *** Error beam           39 has zero area
 *** Error beam           40 has zero area
 *** Error beam           41 has zero area
 *** Error beam           42 has zero area
 *** Error beam           43 has zero area
 *** Error beam           44 has zero area
 *** Error beam           45 has zero area
 *** Error beam           46 has zero area
 *** Error beam           47 has zero area
 *** Error beam           48 has zero area
 *** Error beam           49 has zero area
 *** Error beam           50 has zero area
 *** Error beam           51 has zero area
 *** Error beam           52 has zero area
 *** Error beam           53 has zero area
 *** Error beam           54 has zero area
 *** Error beam           55 has zero area
 *** Error beam           56 has zero area
 *** Error beam           57 has zero area
 *** Error beam           58 has zero area
 *** Error beam           59 has zero area
 *** Error beam           60 has zero area
 *** Error beam           61 has zero area
 *** Error beam           62 has zero area
 *** Error beam           63 has zero area
 *** Error beam           64 has zero area
 *** Error beam           65 has zero area
 *** Error beam           66 has zero area
 *** Error beam           67 has zero area
 *** Error beam           68 has zero area
 *** Error beam           69 has zero area
 *** Error beam           70 has zero area
 *** Error beam           71 has zero area
 *** Error beam           72 has zero area
 *** Error beam           73 has zero area
 *** Error beam           74 has zero area
 *** Error beam           75 has zero area
 *** Error beam           76 has zero area
 *** Error beam           77 has zero area
 *** Error beam           78 has zero area
 *** Error beam           79 has zero area
 *** Error beam           80 has zero area
 *** Error beam           81 has zero area
 *** Error beam           82 has zero area
 *** Error beam           83 has zero area
 *** Error beam           84 has zero area
 *** Error beam           85 has zero area
 *** Error beam           86 has zero area
 *** Error beam           87 has zero area
 *** Error beam           88 has zero area
 *** Error beam           89 has zero area
 *** Error beam           90 has zero area
 *** Error beam           91 has zero area
 *** Error beam           92 has zero area
 *** Error beam           93 has zero area
 *** Error beam           94 has zero area
 *** Error beam           95 has zero area
 *** Error beam           96 has zero area
 *** Error beam           97 has zero area
 *** Error beam           98 has zero area
 *** Error beam           99 has zero area
 *** Error beam          100 has zero area
 *** Error beam          101 has zero area
 *** Error beam          102 has zero area
 *** Error beam          103 has zero area
 *** Error beam          104 has zero area
 *** Error beam          105 has zero area
 *** Error beam          106 has zero area
 *** Error beam          107 has zero area
 *** Error beam          108 has zero area
 *** Error beam          109 has zero area
 *** Error beam          110 has zero area
 *** Error beam          111 has zero area
 *** Error beam          112 has zero area
 *** Error beam          113 has zero area
 *** Error beam          114 has zero area
 *** Error beam          115 has zero area
 *** Error beam          116 has zero area
 *** Error beam          117 has zero area
 *** Error beam          118 has zero area
 *** Error beam          119 has zero area
 *** Error beam          120 has zero area
 *** Error beam          121 has zero area
 *** Error beam          122 has zero area
 *** Error beam          123 has zero area
 *** Error beam          124 has zero area
 *** Error beam          125 has zero area
 *** Error beam          126 has zero area
 *** Error beam          127 has zero area
 *** Error beam          128 has zero area
 *** Error beam          129 has zero area
 *** Error beam          130 has zero area
 *** Error beam          131 has zero area
 *** Error beam          132 has zero area
 *** Error beam          133 has zero area
 *** Error beam          134 has zero area
 *** Error beam          135 has zero area
 *** Error beam          136 has zero area
 *** Error beam          137 has zero area
 *** Error beam          138 has zero area
 *** Error beam          139 has zero area
 *** Error beam          140 has zero area
 *** Error beam          141 has zero area
 *** Error beam          142 has zero area
 *** Error beam          143 has zero area
 *** Error beam          144 has zero area
 *** Error beam          145 has zero area
 *** Error beam          146 has zero area
 *** Error beam          147 has zero area
 *** Error beam          148 has zero area
 *** Error beam          149 has zero area
 *** Error beam          150 has zero area
 *** Error beam          151 has zero area
 *** Error beam          152 has zero area
 *** Error beam          153 has zero area
 *** Error beam          154 has zero area
 *** Error beam          155 has zero area
 *** Error beam          156 has zero area
 *** Error beam          157 has zero area
 *** Error beam          158 has zero area
 *** Error beam          159 has zero area
 *** Error beam          160 has zero area
 *** Error beam          161 has zero area
 *** Error beam          162 has zero area
 *** Error beam          163 has zero area
 *** Error beam          164 has zero area
 *** Error beam          165 has zero area
 *** Error beam          166 has zero area
 *** Error beam          167 has zero area
 *** Error beam          168 has zero area
 *** Error beam          169 has zero area
 *** Error beam          170 has zero area
 *** Error beam          171 has zero area
 *** Error beam          172 has zero area
 *** Error beam          173 has zero area
 *** Error beam          174 has zero area
 *** Error beam          175 has zero area
 *** Error beam          176 has zero area
 *** Error beam          177 has zero area
 *** Error beam          178 has zero area
 *** Error beam          179 has zero area
 *** Error beam          180 has zero area
 *** Error beam          181 has zero area
 *** Error beam          182 has zero area
 *** Error beam          183 has zero area
 *** Error beam          184 has zero area
 *** Error beam          185 has zero area
 *** Error beam          186 has zero area
 *** Error beam          187 has zero area
 *** Error beam          188 has zero area
 *** Error beam          189 has zero area
 *** Error beam          190 has zero area
 *** Error beam          191 has zero area
 *** Error beam          192 has zero area
 *** Error beam          193 has zero area
 *** Error beam          194 has zero area
 *** Error beam          195 has zero area
 *** Error beam          196 has zero area
 *** Error beam          197 has zero area
 *** Error beam          198 has zero area
 *** Error beam          199 has zero area
 *** Error beam          200 has zero area
 *** Error beam          201 has zero area
 *** Error beam          202 has zero area
 *** Error beam          203 has zero area
 *** Error beam          204 has zero area
 *** Error beam          205 has zero area
 *** Error beam          206 has zero area
 *** Error beam          207 has zero area
 *** Error beam          208 has zero area
 *** Error beam          209 has zero area
 *** Error beam          210 has zero area
 *** Error beam          211 has zero area
 *** Error beam          212 has zero area
 *** Error beam          213 has zero area
 *** Error beam          214 has zero area
 *** Error beam          215 has zero area
 *** Error beam          216 has zero area
 *** Error beam          217 has zero area
 *** Error beam          218 has zero area
 *** Error beam          219 has zero area
 *** Error beam          220 has zero area
 *** Error beam          221 has zero area
 *** Error beam          222 has zero area
 *** Error beam          223 has zero area
 *** Error beam          224 has zero area
 *** Error beam          225 has zero area
 *** Error beam          226 has zero area
 *** Error beam          227 has zero area
 *** Error beam          228 has zero area
 *** Error beam          229 has zero area
 *** Error beam          230 has zero area
 *** Error beam          231 has zero area
 *** Error beam          232 has zero area
 *** Error beam          233 has zero area
 *** Error beam          234 has zero area
 *** Error beam          235 has zero area
 *** Error beam          236 has zero area
 *** Error beam          237 has zero area
 *** Error beam          238 has zero area
 *** Error beam          239 has zero area
 *** Error beam          240 has zero area
 *** Error beam          241 has zero area
 *** Error beam          242 has zero area
 *** Error beam          243 has zero area
 *** Error beam          244 has zero area
 *** Error beam          245 has zero area
 *** Error beam          246 has zero area
 *** Error beam          247 has zero area
 *** Error beam          248 has zero area
 *** Error beam          249 has zero area
 *** Error beam          250 has zero area
 *** Error beam          251 has zero area
 *** Error beam          252 has zero area
 *** Error beam          253 has zero area
 *** Error beam          254 has zero area
 *** Error beam          255 has zero area
 *** Error beam          256 has zero area
 *** Error beam          257 has zero area
 *** Error beam          258 has zero area
 *** Error beam          259 has zero area
 *** Error beam          260 has zero area
 *** Error beam          261 has zero area
 *** Error beam          262 has zero area
 *** Error beam          263 has zero area
 *** Error beam          264 has zero area
 *** Error beam          265 has zero area
 *** Error beam          266 has zero area
 *** Error beam          267 has zero area
 *** Error beam          268 has zero area
 *** Error beam          269 has zero area
 *** Error beam          270 has zero area
 *** Error beam          271 has zero area
 *** Error beam          272 has zero area
 *** Error beam          273 has zero area
 *** Error beam          274 has zero area
 *** Error beam          275 has zero area
 *** Warning Massless nodes
     The following massless nodes were found
           3           6           9          12          15          18
          21          23          25          28          30          33
          36          38          40          43          45          54
          55          56          57          58          59          60
          61          62          65          68          77          78
          79          80          81          82          83          84
          85          94          95          96          97          98
          99         100         101         102         111         112
         113         114         115         116         117         118
         119         128         129         130         131         132
         133         134         135         136         139         141
         144         146         149         151         154         156
         159         168         169         170         171         172
         173         174         175         176         179         181
         190         191         192         193         194         195
         196         197         198         207         208         209
         210         211         212         213         214         215
         224         225         226         227         228         229
         230         231         232         241         242         243
         244         245         246         247         248         249
         252         254         256         259         261         264
         266         269         278         279         280         281
         282         283         284         285         286         288
         291         300         301         302         303         304
         305         306         307         308         317         318
         319         320         321         322         323         324
         325         334         335         336         337         338
         339         340         341         342         351         352
         353         354         355         356         357         358
         359         362         364         367         369         378
         379         380         381         382         383         384
         385         386         389         398         399         400
         401         402         403         404         405         406
         415         416         417         418         419         420
         421         422         423         432         433         434
         435         436         437         438         439         440
         449         450         451         452         453         454
         455         456         457         460         462         465
         467         476         477         478         479         480
         481         482         483         484         487         496
         497         498         499         500         501         502
         503         504         513         514         515         516
         517         518         519         520         521         530
         531         532         533         534         535         536
         537         538         547         548         549         550
         551         552         553         554         555
 *** Warning total number of massless nodes =     275
        slave surface of interface   =         1
        type                         =       a 3
        surface timestep             = 1.000E+16
        controlling slave node ID    =      1760
        part ID of slave node        =         3
        current minimum time step    = 1.000E+16
        master surface of interface  =         1
        type                         =       a 3
        surface timestep             = 8.453E-05
        controlling master node ID   =      1766
        part ID of master node       =         6
        current minimum time step    = 8.453E-05
 The LS-DYNA time step size should not exceed     8.453E-05
 to avoid contact instabilities.  If the step size is
 bigger then scale the penalty of the offending surface.
 *** Error initialization completed with     275 fatal errors
           please check messag file
 E r r o r   t e r m i n a t i o n
 S t o r a g e   a l l o c a t i o n
 Memory required to complete solution   :       393385
 Additional dynamically allocated memory:       121159
                                   Total:       514544
小程序用户_ygNnmoBo
你好 请问问题解决了吗  我也有一样的报错
2024年9月6日
