- SIMUFACT WELDING 解答? 暂无回答
PATRAN node 44345 not associated with valid element. PATRAN node 44346 not associated with valid element. PATRAN node 44347 not associated with valid element. PATRAN node 44348 not associated with val
- simufact welding 材料属性 2个回答
RT,刚开始学习simufact,想问下可以在软件里面自定义焊接材料的属性吗?我用的是可伐材料,表面镀镍。谢谢
- simufact welding 仿真出现错误怎么解决? 暂无回答
用软件进行仿真时提示“ process” is aborted with exit 1009,有大佬知道是什么错误原因嘛
