谁知道abaqus零主轴怎么办,求求各位大神指导
浏览:2972 回答:2
Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_1.
Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_4.
Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_5.
<Warning><message type="string">Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_1.</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Warning>
<Status><step type="integer">2</step><increment type="integer">1</increment><attempts type="string"> 1U</attempts><severe type="integer">8</severe><equilibrium type="integer">0</equilibrium><iterations type="integer">8</iterations><totalTime type="float">1</totalTime><stepTime type="float">0</stepTime><timeIncrement type="float">1</timeIncrement><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Status>
<Status><step type="integer">2</step><increment type="integer">1</increment><attempts type="string"> 2U</attempts><severe type="integer">13</severe><equilibrium type="integer">0</equilibrium><iterations type="integer">13</iterations><totalTime type="float">1</totalTime><stepTime type="float">0</stepTime><timeIncrement type="float">0.25</timeIncrement><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Status>
<Status><step type="integer">2</step><increment type="integer">1</increment><attempts type="string"> 3U</attempts><severe type="integer">13</severe><equilibrium type="integer">0</equilibrium><iterations type="integer">13</iterations><totalTime type="float">1</totalTime><stepTime type="float">0</stepTime><timeIncrement type="float">0.0625</timeIncrement><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Status>
<Warning><message type="string">Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_4.</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Warning>
<Status><step type="integer">2</step><increment type="integer">1</increment><attempts type="string"> 4U</attempts><severe type="integer">13</severe><equilibrium type="integer">0</equilibrium><iterations type="integer">13</iterations><totalTime type="float">1</totalTime><stepTime type="float">0</stepTime><timeIncrement type="float">0.015625</timeIncrement><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Status>
<Warning><message type="string">Solver problem. Zero pivot when processing D.O.F. 3 of 1 nodes. The nodes have been identified in node set WarnNodeSolvProbZeroPiv_3_2_1_1_5.</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Warning>
<Error><message type="string">Process terminated by external request (SIGTERM or SIGINT received).</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Error>
<Interrupted><message type="string">Analysis interrupted by external signal</message><phase type="symconst">STANDARD_PHASE</phase><jobName type="string">Job-77zyf</jobName></Interrupted>
<ERROR><message type="string">Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.</message><jobName type="string">Job-77zyf</jobName></ERROR><JOB_RTED><message type="string">Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.</message><jobName type="string">Job-77zyf</jobName></JOB_RTED></msgwrapper>
北望逸尘
零主元有可能是过约束,这个要结合模型各个模块对比分析才能解决
2021年6月23日
李少飞
检查一下模型的相互作用模块,可能是过约束了
2021年6月23日
