ABAQUS不收敛提示下列错误信息是什么原因?
浏览:2210 回答:1
Exhausted the contact constraint pool. The contact pool size is 198236 and the number of activated constraints is 189361. Set the environment variable aba_gcont_pool_size to high or a numeric number (1,2,...) with 1 being equivalent to high.
北望逸尘
接触出了问题
2021年6月29日
评论 点赞 2
