基坑开挖设内支撑中出现的问题,有没有大佬知道这是什么原因?
浏览:1947
OVERCONSTRAINT CHECKS:
 An overconstraint was detected at node 276 INSTANCE SOIL-1. There are multiple constraints
 applied directly or chained constraints that are applied indirectly at this node.
 A list of nodes and chained constraints between these nodes that most likely lead
 to the detected overconstraint can be printed out to the message file by including
 *constraint controls, print=yes in the input file.
