ABAQUS -SIMPACK联合仿真生成.fbi文件出错,为何?
浏览:2321 回答:1
ERROR: Error while parsing the 2th field on line 17489 of the Abaqus file "H:\Job-1.inp".
ERROR: Error while opening .inp files:
An integer value has been expected but the respective field in the FE input file contains non-numeric characters.
其中inp文件的第17489行为:
** BOUNDARY CONDITIONS
** Name: BC Type: Symmetry/Antisymmetry/Encastre
*Boundary
Retained, ENCASTRE
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
*End Step
勇敢的人啊,快去创造奇迹
边界条件改成displacement/rotation试一下
2021年11月10日
