abaqus搅拌摩擦焊数值模拟,老遇到这个问题怎么解决? 10
浏览:2503
An excessive temperature rate occurs in solving the heat transfer equations. This usually indicates that some elements are badly distorted or an error exists with model definition. You can check the temperature values and see if the distorted elements exist.
