请问显示计算中出现Floating Point Exception是什么原因呀? 15
浏览:3006 回答:1
如题,显示计算.sta文件中出现这种问题,采用了VUMAT子程序,请大佬帮忙分析一下原因。
***ERROR: detected in increment 6757 on Domain 1
          after Output Requests.  Job exiting.
***NOTE: Nodes involved in floating point error:
3925 spatial nodes found
    -9912,    -9908,    -9904,    -9900,    -9899,    -9880,    -9876,    -9872,
    -9868,    -9867,    -9848,    -9844,    -9840,    -9836,    -9835,    -9816,
    -9812,    -9808,    -9804,    -9803,    -9784,    -9780,    -9776,    -9772,
    -9771,    -9752,    -9748,    -9744,    -9740,    -9739,    -9720,    -9716,
    -9712,    -9708,    -9707,    -9688,    -9684,    -9680,    -9676,    -9675,
    -9656,    -9652,    -9648,    -9644,    -9643,    -9624,    -9620,    -9616,
    -9612,    -9611,    -9592,    -9588,    -9584,    -9580,    -9579,    -9560,
    -9556,    -9552,    -9548,    -9547,    -9528,    -9524,    -9520,    -9516,
    -9515,    -9496,    -9492,    -9488,    -9484,    -9483,    -9464,    -9460,
    -9456,    -9452,    -9451,    -9432,    -9428,    -9424,    -9420,    -9419,
    -9400,    -9396,    -9392,    -9388,    -9387,    -9368,    -9364,    -9360,
    -9356,    -9355,    -9336,    -9332,    -9328,    -9324,    -9323,    -9304,
    -9300,    -9296,    -9292,    -9291,    -9272,    -9268,    -9264,    -9260,
    -9259,    -9240,    -9236,    -9232,    -9228,    -9227,    -9208,    -9204,
    -9200,    -9196,    -9195,    -9176,    -9172,    -9168,    -9164,     3952,
沦陷_0482
你好,你的问题解决了吗
2024年12月13日
