外部数据导入workbench中警告信息可以解决吗?
浏览:3830 回答:3
面上的压力数据通过workbench中external data导入静力学分析模块中,出现以下警告信息,可以解决吗
The program controlled pinball grew more than 10% of the source point bounding box maximum length. Check results carefully.
During data mapping, target nodes were found outside the boundaries of the source point data. A different method may have been used to calculate the interpolated value. You can find more information by looking at the Summary comment or by turning on named selection creation for outside nodes to help identify these areas.
