lsdyna爆炸流固耦合? 100
浏览:2777 回答:6
按照别人的模型做了几个流固耦合的案例,但是求解的时候老是出现警告和求解时间特别大该怎么解决呢?
 Beginning of keyword reader                                   07/06/22 15:15:11
 *** Warning 11199 (KEY+1199)
     DCT should be -1 in *CONTROL_ALE
 *** Warning 10302 (KEY+302)
     CHECKING MATERIAL INPUT Part ID= 1
     The default hourglass properties of the following
     ALE part are being modified to avoid unnecessary
     application of hourglass forces.
     Resetting coefficient qm=1.0e-6.
     PART ID 1 with
     MATERIAL ID 1 and
     EOS ID 1
     This is PART 1 in the order of input.
     CHECKING MATERIAL INPUT Part ID= 9
     PART ID 9 with
     MATERIAL ID 4 and
     EOS ID 2
     This is PART 9 in the order of input.
 Memory required to process keyword     :    13711070
 input of data is completed
 initial kinetic energy = 0.00000000E+00
 Memory required to begin solution      :     131M
 Additional dynamically allocated memory:      30M
                                   Total:     160M
 initialization completed
       1 t 0.0000E+00 dt 2.12E-04 flush i/o buffers            07/06/22 15:15:22
       1 t 0.0000E+00 dt 2.12E-04 write d3plot file            07/06/22 15:15:22
 *** Warning 40123 (SOL+123)
     There are 145 nodes shared by ALE eleform 11/12
     and other Non_ALE eleforms.
     The first 10 nodes are:
 1 2 3 4 5
 6 7 8 9 10
 cpu time per zone cycle............         0 nanoseconds
 average cpu time per zone cycle....       895 nanoseconds
 average clock time per zone cycle..       815 nanoseconds
 estimated total cpu time          =    514934 sec (     143 hrs  2 mins)
 estimated cpu time to complete    =    514921 sec (     143 hrs  2 mins)
 estimated total clock time        =    469278 sec (     130 hrs 21 mins)
 estimated clock time to complete  =    469265 sec (     130 hrs 21 mins)
 termination time                  = 4.000E+02
韦箫
流固耦合需要流体共节点,并且ALE的part不重合
2022年10月1日
已采纳 评论 1 点赞 1
追风少年62
流固耦合确是需要很多时间进行求解
2022年10月2日
独风
警告可以不用管
2022年7月7日
评论 2 点赞
