使用fric子程序,出现以下错误,怎样解决? 20
浏览:2161
使用cmd进行提交,错误信息为
Run standard.exe
forrtl: severe (24): end-of-file during read, unit 23, file E:\FEA-20220705\Job-2-combination-open-userfric.023
Image              PC                Routine            Line        Source
libifcoremd.dll    00007FFBB291A335  Unknown               Unknown  Unknown
libifcoremd.dll    00007FFBB29675A0  Unknown               Unknown  Unknown
ABQSMAStsShare.dl  00007FFB5A3B911F  Unknown               Unknown  Unknown
ABQSMAStsShare.dl  00007FFB5A1DF34B  Unknown               Unknown  Unknown
ABQSMAStsShare.dl  00007FFB5A41C007  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB2ED07DE1  Unknown               Unknown  Unknown
ABQSMAStaCore.dll  00007FFB31173B45  Unknown               Unknown  Unknown
standard.exe       00007FF7D0B40C8B  Unknown               Unknown  Unknown
standard.exe       00007FF7D0B3DE78  Unknown               Unknown  Unknown
standard.exe       00007FF7D0B56BD8  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFBD6197034  Unknown               Unknown  Unknown
ntdll.dll          00007FFBD65A2651  Unknown               Unknown  Unknown
不使用fric子程序就没有问题,使用就会出现上面的错误。
