求教各位大佬,abaqus里相邻接触对交叉,存在公共边导致不收敛如何解决?
浏览:2368 回答:5
THE SLAVE SURFACES ASSEMBLY_GROUTING-1_G1-I AND ASSEMBLY_GROUTING-1_G2-I INTERSECT EACH OTHER. THEY ARE PAIRED WITH MASTER SURFACES ASSEMBLY_LINING-1_L1 AND ASSEMBLY_LINING-1_L2 THAT ALSO INTERSECT EACH OTHER. IF BOTH PAIRS ARE *CONTACT PAIRs, THESE TWO PAIRS SHOULD NOT BE SIMULTANEOUSLY PRESENT IN A STEP BECAUSE OF POSSIBLE CONVERGENCE PROBLEMS; USE *MODEL CHANGE,TYPE=CONTACT PAIR TO REMOVE ONE OF THEM. IF BOTH ARE *TIE PAIRS, THE REDUNDANT TIES WILL BE REMOVED AUTOMATICALLY. IF ONE PAIR IS *TIE AND ANOTHER IS *CONTACT PAIR, REMOVE ONE OF THEM.
